Home > For Sale & Wanted > Discovery2 LT230 selector housing
Mo Murphy
As above chaps, I need the high/ low box selector housing, the bit with the 6 m6 bolts and the breather in from a cable operated disco2 transfer box.
I believe it has a straight operating arm rather than a dog leg one.
This bit but with a straight arm rather than the cranked one you can see, i think -
Mo
 The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #986059 18th Mar 2023 11:32pm
I should be able to help you Mo, I've converted two Disco2 LT230 boxes to use Disco1 controls (the easiest way to implement the difflock on a 2) so will have the left-over parts. Do you actually need the housing or would the rod/lever be enough? They're easy enough to swap in the housing.
Post #986068 19th Mar 2023 8:04am
Mo Murphy
The shaft and operating arm would suffice BW. Let me send you a pm.
Post #986079 19th Mar 2023 10:09am
