![]() | Home > Puma (Tdci) > 2015 Defender Console Light Issue |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 243 ![]() ![]() ![]() |
You can remove the center part of the dash where the radio etc is seated by undoing the two torx screws and unclipping it all and pulling it forward. You should then easily be able to access the back of those dials.
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149 ![]() ![]() ![]() |
as above - but the lights are in the white mouldings left in the facia inside the dash . .. there are a lot of posts on how to change these if you do a quick search
such as here - https://www.defender2.net/forum/topic16996...=dash+bulb its a ’sticky’ on the forum... ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 373 ![]() |
As a supplement, I don't know the price of the Land Rover bulbs, but you can usually get 10 of them with the description Osram W1.2W 12V W2x4.6d (2721) online for a very good price.
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
From memory I fitted LED bulbs to my 2.2, much better illumination, possibly used these in White
https://www.autobulbsdirect.co.uk/286-t5-l...86led.html NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 786 ![]() ![]() ![]() |
Do they distribute lights equally? The earlier LED units had bright "hotspots" from where the output was focused and dismal light in the surrounding areas
No issues at all, I used LED286W
