Home > Tdi > R380 gearbox identification without a serial number
Davidarnol
United Kingdom 1995 Defender 90 300 Tdi HT Epsom Green
I cannot make out any numbers on the identification flat area beside the drain plug on my R380 gearbox, is there any other external way of identifying it’s suffix or a number anywhere else?
it Is a1995 Defender 90 with a 300tdi engine.
Post #985172 11th Mar 2023 6:16pm
Mdm
not sure if you have had a go at cleaning it up
have tried wire wool after a light sandpaper and a cost of white paint , spray is fine or maybe a chalk pen and then wipe the excess off . doesn't work every time but can pull old numbers up.
Post #985182 11th Mar 2023 7:37pm
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
Road chalk is usually quite good at bringing out numbers on engines and other bits. Just rub it over the area where you think a stamped or raised number should be.
It’s just wax so it shouldn’t cause any issues and will just disappear after a while.
Post #985245 12th Mar 2023 12:49pm
ashtrans
Site Sponsor
post up some photos, I should be able to tell externally Dave
Post #989885 22nd Apr 2023 8:17am
geobloke
It may have been ground off. Reconditioned boxes can be de-serial numbered.
Post #989887 22nd Apr 2023 8:21am
