![]() | Home > For Sale & Wanted > SVX grill, light surrounds, indicators, sidelight |
Drevil Member Since: 03 Jan 2022 Location: Berkshire Posts: 141 ![]() ![]() |
If you’re wondering….the above is this set up:
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 287 ![]() ![]() ![]() |
Hi I have a few questions
Does it come with the headlight backing brackets or loom for the spotlights? Cheers Ash 👍🏻 |
Hi
Just what you see, so no additional brackets and no additional loom on the lights, albeit each has standard connectors so should be plug and play for a vehicle of the right age. Cheers |
Just triple checked the lights. The landrover stamped side lights have standard plugs for existing wiring to plug into.
The Hella stamped indicator units have a little loom from the unit to a standard plug, which then fits existing wiring. If the latter is what you meant by the loom, that’s there. |
Dropped the price, could do with these gone
scotsstag Member Since: 17 Jun 2012 Location: D+G Posts: 546 ![]() ![]() ![]() |
PM sent
Sold
