Home > Td5 > crack in gearbox chassis mount. common?
TexasRover
Hello all,
I am in the process of swapping the transfer case on my 2002 Td5 HCPU and on detailed inspection i noticed the portside (transfer case mount on the chassis was slightly bend and cracked. I straightened it and will weld it but was wondering if this a common issue and maybe i should weld in a strengthening plate?
Post #984876 8th Mar 2023 9:54pm
landy andy
It isn’t something I’ve had, read, or know off. So in my opinion, no it’s not common.
Post #984882 8th Mar 2023 10:32pm
cretesimon
Greece
I look after a few defenders which are used for trips around Crete I have welded quite a few so think it's something that happens with time and stress of the metal
Post #984904 9th Mar 2023 10:31am
DSC-off
The crack has certainly propagated (increased/ spread) due to fatigue.
It has started immediately at the end of the stiff section of the bracket, where the bottom stiffening flange stops. The change in stiffness concentrates stress at that point.
There may have been a small crack in the bracket when it was manufactured, due to the shearing and forming of the material. The crack could have started there.
If it was mine, I would reinforce the whole area with a plate the same thickness as the original bracket.
Post #984908 9th Mar 2023 11:29am
TexasRover
Thanks, yes agree the crack follows a predictable path. The bracket was slightly bend downwards as if it had received a hit at some point.
It is a 2002 but I do have a 1999 chassis chopped in bits lying around and interestingly the same bracket on that frame is much smaller (less wide) so for some reason they changed that. I think the shorter span of the shorter bracket is probably stronger as it will flex less.
Anyhow as I could not be bothered to drill an elongated hole so I just cut the one bracket off to create a doubler plate which I welded in from below. I will check maybe use a longer bolt into the mount, but much stronger now.
Post #984941 9th Mar 2023 3:16pm
