Home > Wheels & Tyres > anyone got 8x16 -32 offset wheels
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
I have spotted a set of wheels on ebay but they are 8x16 -32 offset
will these fit without altering the arches?
I plan on running 265 75 16 tyres on standard suspension but don't really want to be fitting extra width arches if I can help it and wondered if anyone had the same setup. don't want them to look too "Carlos Fandango" Whistle but want something that fills the arches a bit better than the standard boosts
Thanks
Paul 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE*
2010 110 2.4 XS station wagon
Post #984464 5th Mar 2023 2:58pm
Chicken Drumstick
In the UK if the tyres stick out of the arches it is illegal (Construction & Use regs, not MoT). I'd have thought they would be pretty close to sticking of the stock arches.
Post #984478 5th Mar 2023 4:49pm
They shouldn’t protrude any further than the arches as above, if they do you need to fit wider arches to match so the new wider archers are qual to or a little wider than the new tyres. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #984479 5th Mar 2023 4:59pm
camelman
Et -32 will stick way out, even with 265s on.
Et0 is about as far as you can go and stay legal with standard arches and 265s.
Boosts are et33 so an et-32 will be 55mm further out on each side
Post #984520 5th Mar 2023 7:41pm
Can you share a link, Marsie? I'd hazard a guess that they're ET32 rather than -32. Darren
Post #984542 5th Mar 2023 10:23pm
marsie
https://www.ebay.co.uk/itm/115001004878?mk...media=COPY 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Post #984591 6th Mar 2023 3:47pm
marsie
Have decided to stick to the boosts. Have fitted my 265s just need to get my spacers on now to get some steering lock back 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Post #984592 6th Mar 2023 3:49pm
camelman
Yep, those would definitely stick way out from standard arches!
Post #984597 6th Mar 2023 4:35pm
Blimey, they really are -32 Shocked Darren
Post #984599 6th Mar 2023 4:39pm
kenzle8a
-32 would be a bit too fandango even for me.
ET0 is a nice compromise IMO.
Post #984602 6th Mar 2023 5:04pm
camelman
I had 16x10 ET -32s on the 110 but was running 35 inch tyres and 50mm extended arches.
Would look a bit odd with just 265s on there..
Post #984605 6th Mar 2023 6:00pm
