![]() | Home > Maintenance & Modifications > Puma 110 double cab seat belt fixing brackets. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
No, and remember that the front bracket is integral with the seatbelt which would make this difficult.
From memory, M8 x 25, possibly flange head but it doesn't really matter about the head. The rears in particular suffer spectacularly from differential metal corrosion and are one of the worst rot-spots on a 110 DC or SW. The rear brackets are difficult to find in the LR parts catalogues but are APU710010 and are about £45 each. You may find this thread worth a quick look. |
edward Member Since: 08 Jan 2023 Location: Lincs Posts: 151 ![]() ![]() |
Thankyou. So for the front do I need to buy completely new setup? Like this one? Thanks Ed.
https://www.blackhawksolutions.co.uk/evb50...gKHdPD_BwE |
Yes, if you need to replace the bracket you will need a complete new seatbelt assembly. The one you've linked to isn't the right one for a 110DC, though, it is for a soft top 90.
I believe that you need EVB500830PMA on the LH side and EVB500820PMA on the RH side for a 110 DC. They are unfortunately not exactly cheap! (Edited to correct an error - the 110 DC belts are not the same as 110 SW belts as I originally stated.) Last edited by blackwolf on 5th Mar 2023 12:37am. Edited 1 time in total |
Ah thanks again you really do know your stuff! Cheers.
By the end of this I will know exact how much it costs to build a double cab from scratch … |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1064 ![]() ![]() ![]() |
Are these any good to you?
I’ve just come across these https://www.ebay.co.uk/itm/155438211841?mk...media=COPY 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
Unfortunately not, those are 110 SW or USW belts, which have the inertia reel mounted in a different place to the 110 DC.
Although I am pretty sure that the rears are M8, I had a glance at the front mounting on my DC whilst out and about today and I think that the fronts are actually M6, the heads look to be 10mm AF rather than the 13mm AF of an M8. I suggest that you check on your own vehicle before buying new. |
Thankyou. Taking it to the body shop tomorrow so I’m going to ask them to take them out and I can order new stainless ones. Thanks again for all your help.
