![]() | Home > General & Technical (L663) > Changing a set of wheels |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 452 ![]() ![]() |
Invest in a good 4T floor jack with a minimum height of 22" or higher.
Jacking points a fine and safe to use. The new floor jacks have a double plunger/cilinder and jack up very quickly. They also use a cardan coupling instead of gears which are proned to wear quickly. No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3482 ![]() ![]() |
This might be of use
![]() https://topix.landrover.jlrext.com/topix/c...745447!0!5 24MY 90 D250 HSE, Tasman Blue |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
I use a bottle jack, because a trolley jack can’t be used in all situations as it depends what the ground surface is. But if you have a solid floor garage or something like that then a trolley jack is faster and easier.
In an ideal world having both would be ideal, but as I said depends on situation. Each one has its different positives and negatives. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
I have an exhaust jack for this.
