Home > Maintenance & Modifications > Long standing Td5 resurrection
peaceman
United Kingdom 2003 Defender 110 Td5 CSW Bonatti Grey
My Defender TD5 has been standing for at least a year, unfortunately I haven't been able to keep up with regular starts. I'd like to get it fired up again but would like to minimise any damage when I do. It was fully serviced just before its long rest and is in good shape mechanically.
Would greatly appreciate any advice on steps I should run through before doing so?
For example; syphon and replace fuel? Replace oil/fluids even if brand new before standing?
Is there any risk that cylinders will be dry?! I should mention that it is on a slight incline. If so is there a non-invasive way to lubricate?
Cheers!
Post #984154 2nd Mar 2023 10:57am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Start it in the normal way. Worse case if it doesn’t start, but I very much doubt it - run a purge cycle then start.
Post #984164 2nd Mar 2023 11:42am
hank
You could take the injectors out then spin it over on the starter to pump oil around and get oil pressure. Then put them back in and fire it up Thumbs Up > 110 XS Double Cab
Post #984168 2nd Mar 2023 11:52am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Mine has been stood in the garage for 5 years now, This was planned and had an oil change before the lay up.
I will be using it this year, I have cranked it a few times. Just remove your fuel pump relay and crank for a bit. You should hear the oil pressure build up.
Some fresh fuel as soon as it's running then another oil change with fuel/oil filters.
Post #984192 2nd Mar 2023 4:32pm
BrickBox
Spin it on the starter with the injectors unplugged for 30 seconds or so. That’ll build up oil pressure and then just fire it up. 12 months isn’t that long. Should be fine IMO. 2008 2.4 110 Utility Station Wagon XS.
Post #984211 2nd Mar 2023 7:02pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
When I picked up out latest 110 Td5 which had been stood for 3years, I took the fan off to gain access to the crank pulley and I put a socket and ratchet on the crank pulley to make sure it hadn't seized.
It hadn't so proceeded to fire it up and it was fine.
cheers
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #984285 3rd Mar 2023 12:51pm
landy andy
Wouldn’t just unplugging the crank sensor be an easier option?
Post #984300 3rd Mar 2023 4:21pm
Hufflepuff
I think by "unplugging the injectors" we are talking about the electrical connection on the front of the engine where the rocker cover internal loom connects with the external loom - not disconnecting the injectors themselves individually Smile 2005 Td5 90 XS
1989 V8 110 CSW
Post #984310 3rd Mar 2023 5:42pm
