Home > Technical > Headlamp Alignment Switch -Illumination
Albarker55
2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Having replaced all the dash bulbs and all controls are now illuminated, I have a question relating to the headlamp alignment switch. Is that illuminated and if so where is it’s bulb located? Is it an internally lit switch like the other switches eg hazards?
Grateful for some enlightenment if you will pardon the pun
Post #983677 25th Feb 2023 8:54pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi. Yes mine had a green led soldered onto the board. Very dim. I ordered led bulbs from ebay I think, and soldered a pair onto the board. Lights up a treat now.
Prior to that, I had issues with the switch not working. Stripped it and soldered all the joints again and has worked perfectly since. 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #983705 25th Feb 2023 11:25pm
geobloke
As above Thumbs Up Did the same thing with the AC switches.
Post #983729 26th Feb 2023 10:46am
Albarker55
Thanks both for your replies. Guess it’s the dash out again and some switch disassembly and repair effort. Any clue on the LED bulb and where on eBay I can get one.
Post #983731 26th Feb 2023 12:11pm
geobloke
Of course, here you go https://www.rapidonline.com/barthelme-2110...en-57-6825
I chose the green LEDs to keep with the Defender lighting theme. FYI it is the same bulb in the headlamp levelling switch as well. Thumbs Up
Post #983734 26th Feb 2023 12:42pm
Albarker55
Thanks for the link. All ordered. Will attack the switch refurb over the next couple of days
Post #983797 26th Feb 2023 8:49pm
geobloke
You're welcome and good luck Thumbs Up
Post #983799 26th Feb 2023 8:51pm
matchap801
From memory, there is a fiddly little spring inside the body? Use a hair drier to warm the outer case so it flexes to pop it apart! 2009 Defender 90 CSW 2.4 TDCI.
Post #983800 26th Feb 2023 8:53pm
