![]() | Home > For Sale & Wanted > [Wanted] Hi-Cap Fuel Filler Assembly |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878 ![]() ![]() ![]() |
Bit of a longshot, but does anyone have a spare Hi-Cap fuel filler assembly? The later type to suit the plastic fuel tank.
Thanks in advance. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 341 ![]() ![]() ![]() |
Which bit?
If you are talking number 4 then they appear to be common for all diesels. I have a spare one of these if interested. ![]() Click image to enlarge All the info on here: https://www.lrworkshop.com/diagrams/land-r...ller_45023 |
Hi Both,
I'm looking for this bit: ![]() And the fuel filler neck itself (the later plastic type as per V8bob's link). A full assembly Inc hoses would be ideal. 1985 127 V8 Build Thread Series 2 109" Series 1 80" Last edited by Shroppy on 25th Feb 2023 11:23pm. Edited 1 time in total |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1247 ![]() ![]() ![]() |
Well I'm mistaken - I didn't have the fuel filler on the cherry picker. Just had a look through the old photos from when I unloaded it from the trailer and there isn't anything installed there.
Sorry, thought it did have one which I'd removed but I was mistaken. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
No problem, thanks for taking the time to check.
![]() Series 2 109" Series 1 80" |
td590brad Member Since: 30 Nov 2014 Location: Sussex Posts: 203 ![]() ![]() ![]() |
I have one from a 1991 with the filler neck if that’s any good ? Was Td590brad.. then pumabrad... then back
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
Brad,
Do you have the rear body sills, behind the rear wheels? |
Hi
Yes I think I have a pair, I’ll check and let you know Is the filler neck of interest to you ? Thanks Was Td590brad.. then pumabrad... then back ![]() |
Hi Brad,
Could you pm me a photo of the filler please? Apologies, missed your earlier replies. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
