![]() | Home > General & Technical (L663) > New Defender - heated seats question |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
They may not be fitted because of your market’s spec requirements. I’ve seen on other forums comments that in many hot climate countries you don’t get heated seats. It wouldn’t surprise me if you do have them fitted up but just not connected/ wired in as with many of the options like adaptive cruise control - everything is there but it is not enabled Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2782 ![]() ![]() |
I didn’t know you could get them without heated seats. Even my base spec has them, so perhaps the heating elements are in there?
cestor Member Since: 29 Dec 2022 Location: The desert Posts: 32 ![]() ![]() |
That's what I'm thinking...how can I check?
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
This may help:
https://store.landrover.com/parts/index/hi...and-rover/ 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
OP is showing a location of Israel and an LHD vehicle - maybe JLR thinks that there is no need to have heated seats in that market Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3450 ![]() ![]() |
Heated seats are part of the "cold climate pack" (heated seats, screen, steering wheel, and washer jets)
lt seems to be standard on most versions, but maybe not vehicles sold in hot climates. l got it on my base spec Commercial because l ordered the leather steering wheel, and l am glad l did if only for the heated screen. |
The base spec here has 14 way memory seats with heating so they should be there in theory although the build sheet says not. I'm thinking semiconductor shortage.
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 283 ![]() ![]() |
Lightening . Heated seats are not part of the cold climate pack, only heated washer jet, headlamp washers and heated steering wheel, if not fitted as standard. In my case it was only the washers as the heated steering wheel was standard. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Yes you are correct, my mistake
