![]() | Home > Puma (Tdci) > LOF clutch assist spring |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
clutch bite point can be adjusted on the clutch master cylinder under the bunnet under the plate with the 6 screws, I think there is a set up guide on the LOF website if not the LR manual DEFENDER 90 TDCI XS,
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6048 ![]() ![]() |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3643 ![]() ![]() ![]() |
I think that drawing only represent earlier than tdci clutch pedal boxes. MY12 does not have an adjust screw for pedal height, but there is an adjust screw to limit how far you can push the pedal.
Completely opposite of what I have in my 1988 90 which is perfectly depicted by the illustration above. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
miker916 Member Since: 25 Oct 2022 Location: Fife Posts: 64 ![]() ![]() ![]() |
thanks all, i'll try adjusting the clutch master cylinder push rod
Ensure that there is still clearance between the push rod and the master cylinder piston. This is because if you apply a bit of pressure on the piston, it shuts of the non return valve on the reservoir, and no new oil from the reservoir gets into the system to replace any lost fluid. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
