![]() | Home > In Car Electronics (L663) > 12V socket - Will it draw charge whilst off? |
If there is a light then yes it will be drawing power. The only way to know how much is to test the current being drawn and deciding whether that is too much for the battery.
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
It may also turn off when the car goes to sleep… (See the Powerful UK battery videos on YouTube)
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20906 ![]() ![]() |
If you want 12v socket supply whilst off, it must not have any LED or pilot light on it or it will drain all by itself.
It must be without illumination, and also likely needs wiring back to batter and fused in-line near the battery or suitable near junction box and fusing with a permanent 12v supply with ignition off. Bluesea 12v sockets are ideal. But must not be illuminated otherwise you’ll get parasitic battery drain. If you really did want illumination whilst also having a permanent 12v supply with car shut off. Then you’d need the illumination separately wired for ignition on only or with lights and interior light or similar arrangement. Obviously then the illumination would go off at rest but 12v supply would still be present. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Surely any USB outlet connected to the 12 v socket will have a permanent current draw, unless the vehicle switches off the 12 v circuit.
USB outlets convert the 12 v to 5 v using a circuit board which is not switchable and will be permanently on. A marker light will add slightly to the draw. I think it is these circuit boards that are in short supply. |
Yes, if it’s USB. Then perhaps a maul switch maybe useful instead but could be easily left on by accident.
OR use 12v socket and just plug in a USB Dalit into it only when required. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
