Home > Puma (Tdci) > A replacement front axle for Pumas?
spudfan
Ireland
Perhaps a replacement for the dodgy Puma front axle?
https://www.maer.com.pl/front-axle-for-def...,3678.html 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #981921 9th Feb 2023 9:31pm
DSC-off
All axle elements are laser cut and shaped with CNC brake press.
The majority of it is flat laser cut plates, fitted together with tabs and notches. The press brake bending appears to be only on part of the diff housing.
The strength of this axle (Maer) is totally reliant on the welds, lots of them, everywhere.
Personally, I'd be looking for a pre 2010 or post 2013 axle if concerned about the original.
Post #981932 9th Feb 2023 11:29pm
spudfan
Ireland
I bow to your superior knowledge. Bow down 1982 88" 2.25 diesel
Post #981967 10th Feb 2023 11:56am
It looks very similar to the HD axle Britpart sells to me.
Post #981973 10th Feb 2023 12:13pm
jimbo55
Britpart just sell the Maer ones
The do make portal ones as well which were quite tempting
Post #981977 10th Feb 2023 12:52pm
kenzle8a
I’d guess it’s made by Maer for them, ive always been more skeptical of these big diff pans after watching the Banks Power channels stuff about them
Post #981998 10th Feb 2023 4:12pm
Indeed, I really want the smallest lightest axle case that provides strength that is adequate with a reasonable margin of safety, not something that looks more like and oilfield truck axle.
If I needed new axle cases I'd be tempted to try to get the reinforced military type and rework them as required. Alternatively I'd use standard cases and get my friend (who happens to a coded welder) to improve them sensibly.
Post #982002 10th Feb 2023 5:05pm
Chicken Drumstick
Re: A replacement front axle for Pumas?
What do you consider to be dodgy with the standard axle?
Post #982239 13th Feb 2023 1:42am
spudfan
Ireland
Some of them have bad welds which could lead to the axle failing. Pretty hot topic on here.
https://www.defender2.net/forum/topic55655.html
https://www.defender2.net/forum/topic33029.html 1982 88" 2.25 diesel
Post #982240 13th Feb 2023 1:50am
Chicken Drumstick
ok, seems a bit of a knee-jerk reaction then to replace the entire axle with another if it isn't actually broekn. Plenty don't have the issue, or you could just get yours re-welded if worried.
Post #982436 14th Feb 2023 2:34pm
Although I tend to agree with your sentiment, you really don't want to wait until it is broken since by then you may not be alive. Having the swivel housing break off the front axle is hardly a minor fault, whatever JLR may say.
Personally I feel that some form of preventative intervention is appropriate but replacing the axle case with the monstrosity above is not the optimal response. The LR-designed "catch brackets" are probably a more balanced measure, although that is easy for me to say since my Defender is outside the VIN range to which the defect is supposedly related, as are several of the reported failures on the forum. How I would feel if I was in the affected range is harder to speculate.
I do have the brackets fitted to my Defender and would certainly want them on any Defender I drove regularly.
Post #982438 14th Feb 2023 2:59pm
Dinnu
You do not need to replace the entire axle, only the axle case, and re use your existing internals. Probably a lot of Discovery 300tdi going to the metal recylers. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #982451 14th Feb 2023 5:57pm
