![]() | Home > Puma (Tdci) > Noisekiller overheat |
Many thanks to you and all other contributors ![]() But shout it at them in German because life is also terrifying and confusing... |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2479 ![]() ![]() ![]() |
I was told a larger one could cover the bellhousing also. You better ask the people of NK Puma 110" SW
Will do - calling them tomorrow ![]() But shout it at them in German because life is also terrifying and confusing... |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I don't know how to refer to links but if you look at page 2 of the tdci section there's a thread entitled "noisekiller engine blanket highly recommended" and I have a picture of it there. As the title suggests I highly recommend it ....
Even better - now I know what to ask them for ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
I don't have a Puma, but I have just this evening fitted the largest one to a Td5 and even that wasn't as big as I thought it would be.
I'd take their advice though. |
![]() Click image to enlarge It seems rather small to me... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
what you can't see in the pic is the big flap that goes down the back of the engine so its bigger than it looks.
Also since taking that pic I have 're moulded' it a bit so that I have full access to the dipstick without having to bend it upwards - not that it was a problem as it doesn't seem to burn any oil! |
dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173 ![]() ![]() |
Hi,
Could any body tell me how to insert the noise reduction foil through the metal casing under the puma bonnet. And also the approx. thickness of the foil+sponge if available? Cheers! ![]() ![]() Regards, Diluk |
