![]() | Home > Puma (Tdci) > 2.4 TDCI starter / coolant / heater / loss of power issue |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20980 ![]() ![]() |
Try replacing the CHT sensor which has been discussed recently on here it isn’t expensive.
Is it losing any coolant or staying at the level it should be? As the battery has been replaced, check the connections are tight and the main ground lead secure. Check the voltage on it at rest and when motor is running to check voltages are appropriate. How old is the water pump? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 14th Feb 2023 11:26pm. Edited 1 time in total |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
head gasket...?
Andyyav Member Since: 01 Jan 2023 Location: norfolk Posts: 6 ![]() ![]() |
Thanks for the info, does the CHT sensor have some ‘control’ of the coolant system or are you thinking it could affect the starting? Occasionally the glow plugs don’t come on when expected, turning the ignition off then back on fixes this He did say he topped the coolant up a few weeks ago about a litre from memory, I looked for leaks but couldn’t see anything on the ground or around the hoses, I guess a small leak could evaporate before leaving a mark, I believe the water pump is original it’s done 91k, alternator was checked (not by me) when the battery was replaced, I did check connections and earths when investigating the starter motor all appear fine, as for head gasket doesn’t appear to be any oil in the water or sludge in the oil filler, is there anything else to look for in regards to the head gasket? |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
On the 2.4 the CHT sensor feeds to the engine ECU and the coolant temperature is calculated from it and this is displayed as coolant temperature on the dash gauge. I believe it is also used to decide if the glow plugs should be activated. So this could be one of your issues. At circa £30 it’s not expensive to replace and would be my first thing to change.
Re the other issues around the heater etc, it could be air in the system, could be coolant expansion header tank cap, but if not does seem to indicate a head gasket issue. |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 533 ![]() ![]() |
If you arent getting the glow plug light on a cold engine and non start check the main relays under drivers seat for corrosion or poor terminal connection.
Thanks all, I’ve checked and repaired the relays under the drivers seat, I think I’ll replace the sensor and check / bypass the cabin heater control valve to rule it out, just hoping it’s not the head gasket I’ve done some searching and it looks cheaper to buy a second hand engine if it’s the case
Had some time today to carry on investigations, still using water still no heat in the cabin.
Spotted some coolant residue near the water pump, removed the pump to find the below pictures which gives me or should I say the wise members of this forum more questions! Where has the leak come from, pump? Gasket? Casing? Is it a common failure? What should I look to replace? Also checked the heater control valve it’s a bit stiff compared to a new one, I’m guessing the loss of water is causing the lack of heat? I plan to flush the heater matrix, rad, oil cooler and pipes tomorrow. Any thoughts on the leak appreciated! ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Mine leaked the last few weeks and I replaced mine too, coincidence likely caused by the freezing temps we had.
It happens. First one I had went on the gasket between the two pump casings. The last one on the joint between the pump and manifold. I replaced the entire coolant whilst I was at it this time. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Valuable info, I think this one was letting the coolant down the shaft if that makes sense?
New one and gaskets fitted yesterday I carried out the bleed procedure as per WSM but keep getting air in the heater control valve, ill take it for run round today to get it to temp and see if that helps |
Went through the bleed procedure a couple more times and drove it round for a bit all appears well and there’s heat in the cabin!!
Was a little confused that the expansion tank and heat control valve appear to be the same level but I guess that’s how it’s designed!! Thanks for all your helps I’ll be back next time something else crops up!! |
