![]() | Home > Puma (Tdci) > ABS Front sensor pickup |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1008 ![]() ![]() ![]() |
Possibly just erase the fault code to reset. See if that works. Hopefully it won’t re-occur. 2008 2.4 110 Utility Station Wagon XS.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
The trigger ring is part of the CV joint, so if that wasn’t replaced with a non-abs one then that shouldn’t be the problem. 2007 110 TDCi Station Wagon XS
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
Hello,
Couple of things to try, Remove the sensor from the hub, and reseat- sometimes they stick in the small cage thing that is supposed to hold them still. Check the spacing on the end of the halfshaft/CV if its not correct it can make the car throw a wobbler. If it was done by a garage I'd probably just punt it back to them to check. Chris |
TC909 Member Since: 27 Jul 2021 Location: Lincolnshire Posts: 39 ![]() ![]() |
Thanks for the info, after cleaning & reseated both and I went for a longer drive and the TC light is now out.
