Home > General & Technical (L663) > Recall on i6 engine
brucehun
South Africa 2003 Defender 110 Td5 DCPU Java Black
Recall on i6 engine
Post #981474 6th Feb 2023 11:54am
lightning
Hard to tell really. l imagine anyone whose vehicle needs checking will receive a letter
Post #981488 6th Feb 2023 2:15pm
stevemfr
France
The problem is, this recall was filed with the NHTSA in the US (pdf attached to article). This means that only NAS vehicles will be covered by this filing and LR does not sell diesel vehicles in the US. The AJ20 P6 and AJ20 D6 share numerous components - I have no idea if the cam carrier is amongst them or not (and I was not able to figure this out on a very quick search just now - no more time). The valve train is different due to the variable valve timing on the petrol models, though.
My car could theoretically fall into the VIN range, but I have a D250. When I was last on Topix about 2 weeks ago nothing but the 2nd key was listed as outstanding. I'll have to check again when I have a min.
Thanks for the heads-up.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #981489 6th Feb 2023 2:24pm
silent_fury
Romania
Well, this is a D300 Engine.
Oil leak on passanger side.
The post is on FB The New Defender Owners Group.
Only 8000K miles.
Post #982155 12th Feb 2023 11:24am
lightning
l guess owners should keep an eye out for oil leaks then.
Post #982185 12th Feb 2023 6:31pm
Co1
“They all do that Sir…” Rolling with laughter
Post #982192 12th Feb 2023 7:05pm
lightning
Good old Facebook strikes again
Where's this oil leak supposed to come from, once l've cleaned my drive of the oil that leaked out of my old TD5 Defender l'll keep a look out for it.
Although on that FB post it sounds like the engine has let go and not just an oil leak.
Post #982203 12th Feb 2023 8:10pm
Sepp
Germany
Other countries' authorities will follow with recall information for sure.
It's not unsusal for NHTSA to be much quicker with publishing recalls.
Post #982308 13th Feb 2023 5:24pm
