![]() | Home > Puma (Tdci) > Bunny - the great Puma update. |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge All done. 4 challenging days across a few weeks. I ended up needing left front and rear wheel bearings. Several test drives later, the brakes are settling in a treat and there are no leaks yet. The hard work of searching for all the different bits paid off!!!!! ![]() Click image to enlarge 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. Last edited by matchap801 on 20th Mar 2023 11:45pm. Edited 1 time in total |
defenderfraggle Member Since: 06 Dec 2022 Location: Leiden Posts: 24 ![]() ![]() ![]() |
I need to do some dash leds as well. But am having trouble to find the small ones. Do you have partnumbers for all the bulbs?
These were for the clock - much better - https://www.ebay.co.uk/itm/191416871350?mk...edia=EMAIL
These were for the dash/heater controls - again much brighter - https://www.ebay.co.uk/itm/261260023574?mk...edia=EMAIL I hope this helps. Regards. Mat 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
Great! Thank you very much.
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 369 ![]() ![]() ![]() |
Nice job!
I really think it's worthwhile documenting your build as so much time and effort goes into the planning and design, let alone the time doing the work. TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
Indeed. That was four tough days to do the brakes and seals. Costs were more than I had planned - bit it was worth it. Plus all the work I did at the start of ownership.
Completely forgot I had put one pice drive shafts in the rear until I pulled them out! 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
[quote="matchap801"]These were for the clock - much better - https://www.ebay.co.uk/itm/191416871350?mk...mp;media=L
I received the lights today, wanted to change them, but when you said click did you mean the speed clock or the time? I tried to change the lights in the speed dash, but could not find any… |
Hi. I replaced the bulbs in the time clock and also the dash heater controls. I know some have changed the speedo and rev counter bulbs but I haven't. Yet! 2009 Defender 90 CSW 2.4 TDCI.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
I take my hat off to you to take that much work on.
![]() Regards dash LED’s, I did that before but was very disappointed. At first, they seemed great, brighter, cooler running etc. Then they started flickering, on and off some went off completely others didn’t. Some worked fine permanently, others kept flashing, others stopped working. In the end, I replaced them with standard ones again back to where I started as they actually seemed to last longer than the LED’s. Mind you if you have good LED’s they might be great but mine were duff. I was going to replace the clock bulb for LED also, but glad I didn’t as I could see the same happening. Hope that yours are better than the ones I had. What drive flanges where you thinking of for the front? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
![]() Click image to enlarge I tried two types of LED. The ones with the single wires in the base didn't work well at all. The ones with the printed circuit board style have been excellent. After a very tough off road weekend on Salisbury Plain I am pleased to say my hard work all paid off. As for drive flanges - I used a second hand Disco Series 1 solid pair on the back (lots of noise gone) straight swap. As for the fronts, I have stuck with the originals, cleaned greased and refitted with original shims and spacers, all is working ![]() Click image to enlarge ![]() Click image to enlarge 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
ah ok, cool. I know how to do those. Will do so this weekend (hopefully). Thanks! |
