![]() | Home > Puma (Tdci) > puma 10AS removal for testing |
| Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159
Probably need to relearn to vehicle and plip units. easy to do with the appropriate scanner or a good mobile auto electrian. Its never over in my land rover.
2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
| matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120
Disconnect the battery first - correct sequence in the handbook - then on reconnect, press the Lock? Button five times to resynch -
Loosen the terminals, turn the ignition on, turn the ignition off, disconnect the negative. There are a few companies who refurbish 10AS and remotes, but as mentioned you should try to resynch yourself first https://www.defender2.net/forum/topic66476.html 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2533
One point to note is you won’t be able to start the vehicle without it fitted. Well unless you have had the immobiliser mapped out of your Engine ECU.
Technozen specialise in Lucas 10AS repairs. https://www.technozen-electronics.co.uk/la...-services/ Out of interest what are the issues that lead you to believe the unit needs repair. |
| Marcus68 Member Since: 15 Jan 2023 Location: Wiltshire Posts: 16
Hi there, reason’s for thinking 10AS unit faulty were - central locking not working properly, cranking of the engine was for maybe 4seconds only then nothing. Alarm system armed itself and flattened the battery. I removed the as unit & sent to techozen . He tested it & said no fault but refurbished the key fob as it was broken. Supplied another new fob for spare also . Since fitting back on & pairing to vehicle it has been fine.
Pleased to hear you received a professional service and had the fault rectified at what I expect was a reasonable price.
The key fob works in conjunction with a receiver near the ignition switch which signals the 10AS , hence a broken fob was not recognised and the 10AS would not signal the engine ECU to allow it to start. In essence the 10AS was doing the job it was designed for |
The dreaded non start problem’s have come back again . Sometimes when cranking the door locks try to operate as if there’s a problem with immobiliser but I’m not sure. Another thing I’ve noticed is the clock on the dash is going backwards? Loosing faith in this thing now.
Clock going backwards can happen after changing main battery.
To fix you can try setting the time going forwards, else pull fuse , replace , and then try setting time. If it does not work first time it should after a couple of try’s. |
Many thanks, I will give this a try.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
You Defender is not related to Stephen King's Plymouth Fury "Christine", is it? |
😂 I forgot how the film ended was it in a ball of flames 🔥
