Home > Puma (Tdci) > Noisekiller overheat
ZeDefender
I want to fit a noisekiller under my bonnet (if I can get someone to send to Germany) but there doesn't seem to be much clearance Sad
If it ends up pressed down against the engine, won't it cook something (and/or make it louder)?
Matt Tell someone you love them today because life is short.
Post #98064 4th Nov 2011 2:29pm
MartinK
I guess you mean the NK "Blanket"...
I already have the NK soundproofing that is self-adhesive under the bonnet, and it seems to make a small difference.
Instead of NK blanket, I am waiting to see what happens with this: http://www.defender2.net/forum/topic8633.html
If the 2.2 is quieter, and the engine cover makes a difference (and fits!) so long as the price is reasonable this looks a good bet to me... I assume this will give good access to check and top-up oil etc...
Waiting to see when they come out... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #98065 4th Nov 2011 2:39pm
ZeDefender
Waiting to see when the come out...
Yep, the blanket Smile
Did you fit it under the whole bonnet underside or just the bulge?
Did it make a significant difference?
If not, I won't bother as it will cost me a king's ransom to get it shipped here Sad
Post #98066 4th Nov 2011 2:43pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
I fitted the under-bonnet NK insulation and it made a small but noticeable difference. I then fitted the NK blanket and it made a HUGE diffference!
Matt
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #98068 4th Nov 2011 2:54pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Mine's apparently arrived at home this afternoon, I'll be fitting it later Very Happy
In theory if your cooling system works ok, it shouldn't overheat your engine. The heat rejection provided by the coolant/radiator is massively (as in hundreds of times) greater than the heat rejection directly off the top of the engine, which is where the NK blanket goes. After all modern engines (like the Td5 etc) already have a foam/plastic cover on the engine.
Plus I figured what with living in the UK and driving a 110 which rarely sees a heavy load, it should be fine. Particularly as the massive viscous fan on the engine is waaaaay OTT for most applications. I used to run my old 90 through winter without it Shocked
Post #98071 4th Nov 2011 3:24pm
MartinK
Yup I only have the under bonnet stuff - looks like this:
But now...
I'm waiting for the 2012 cover as per dgardels' post:
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #98072 4th Nov 2011 3:26pm
ZeDefender
Sorry for my "thickness" but what's the difference between NK "insulation" and "blanket"? Does the "blanket" stick under the bonnet or sit on the engine?
Any chance of a pic of a fitted blanket and perhaps the website of the one you bought? I can only find self-adhesive stuff you cut yourself.
Cheers Tell someone you love them today because life is short.
Post #98074 4th Nov 2011 3:35pm
MartinK
The "Insulation" is self adhesive and sticks under the bonnet as my photo above
For Blanket:
There's a video half way down this page:
http://www.noisekiller.co.uk/acoustic_blankets_products.asp
or here on youtube:
Post #98075 4th Nov 2011 3:38pm
twopoint6khz
The 'insulation' is an adhesive-backed foam covered in foil, which you stick to the underside of the bonnet as in the photo above.
The 'blanket' actually straps to the engine (i.e. stays in place when the bonnet is lifted) and is made of a sheet of lead between two foam pads, all encased in a fabric bag. There are eyelets to hook it onto fixtures to keep it still.
I'm guessing on more modern Defenders (Td5 onwards) you'd have room for one but not both - although I haven't tried it so I don't really know.
Post #98076 4th Nov 2011 3:40pm
Happyoldgit
Insulation sticks to the underside of the bonnet.
Blanket goes over the top of the engine.
I went the full NK route on one of my TD5's with insulation all over the place but the blanket made a big difference and I never cooked the engine or any ancillaries. Steve.
http://forums.lr4x4.com
Post #98077 4th Nov 2011 3:42pm
ZeDefender
Great - I'll be getting a blanket somehow Thumbs Up
Any advice on the size? The website says "Small 500x500mm, Medium 750x500 and Large 925x500". Do I want it over the entire engine compartment?
Post #98093 4th Nov 2011 5:45pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
I shouldn't worry about overheating a Defender - your not in Africa!!
I took the viscous fan off my TD5 a few weeks back and the temp guage hasn't budged from normal position.
Includes motorway driving, 3 hours green laning and day to day driving.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #98107 4th Nov 2011 7:20pm
ZeDefender
Thanks - you've convinced me Smile
but how big should I go (pfnaah, pfnaah)?
Noisekiller do them in 500x500mm, 750x500 and 925x500 - not sure if I should cover the whole engine compartment or just the engine...y bit (must be a technical term for that Rolling Eyes ) Tell someone you love them today because life is short.
Post #98108 4th Nov 2011 7:29pm
MK
500x500mm. Puma 110" SW
Post #98117 4th Nov 2011 8:50pm
leeds
Steve Thumbs Up
Be very careful with no fan.
YES on normal driving you do not really need a fan as the ram effect of air through the radiator is normally sufficient.
Engine coolant normally boils between about 106 to 120C dependent on the concentration and pressure of the coolant system.
The standard LR temperature gauge in a 300 TDi sits just to right of 12 o'clock. For it really to shift from this position the coolant temperature needs to hit around about 106C to get into the red zone. i.e. it is above boiling temperature of water.
Quick question how often do you look at your temperature gauge?
We have boiled coolant due to a fan problem. Outside temperature was -6C. However we had been crawling up a mountainside in low box so no real air ram effect through radiator. On return to UK it was replacement head gasket and a precautionary head skim.
Now we run engine watchdog system and this gives us an audible signal when coolant is about 96 C i.e. well below boiling point of normal water.
So yes you can run without a fan if you want to run higher risk of doing head gasket etc in!
Brendan
PS We were not in Africa, but up a mountain in Spain
Post #98120 4th Nov 2011 8:55pm
