Home > Maintenance & Modifications > Filler neck extension for late '98 Defender 110"
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
Hello,
I'm looking for the later equivalent (superceding part) of this:
NTC2655 | Extension Pipe - Fuel Filler | Defender To 1998
I'm pretty sure that I bought one of these and found it too large in diameter to fit my 1998 Defender (the trim has 11/98 as the build date code) and VIN WA146xxx
Any idea why this part changed?
The LR Workshop page only lists one part number:
https://www.lrworkshop.com/diagrams/land-r...9806_53476
Post #980286 29th Jan 2023 12:21pm
Retroanaconda
For Td5 they changed to a different (plastic) filler neck with a screw-in fuel cap. I’m not sure if there is an extending section available for this type.
The one you have listed is for the pre-Td5 metal filler necks which are larger in diameter and have a cap that closes in a different way.
Post #980291 29th Jan 2023 12:45pm
spudfan
Ireland
Yes as stated above. My series 111 has one fitted which can be removed but it will not fit into a Td5 or Puma as they have narrower filler necks. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #980342 29th Jan 2023 5:04pm
TexasRover
Actually a feature I use regularly on my Series 3 and I missed the other day on my Td5.
Post #980355 29th Jan 2023 5:48pm
geobloke
Is there any reason you couldn't fit the older type of filler and cap so you can have the extension? The filler recess in the body panel is the same size.
Post #980491 30th Jan 2023 2:34pm
spudfan
Ireland
It's mating the filler to the tank would be the problem. 1982 88" 2.25 diesel
Post #980494 30th Jan 2023 2:47pm
Retroanaconda
Yes, it’s a larger diameter hose. But a reducer could be easily made up to adapt the two bits of hose together.
Post #980512 30th Jan 2023 4:30pm
spudfan
Ireland
Good idea. A flexible end to join to the tank would allow the pipe to taper to the tank. 1982 88" 2.25 diesel
Post #980517 30th Jan 2023 5:07pm
geobloke
Thumbs Up Thumbs Up
Post #980520 30th Jan 2023 5:47pm
Just what I did on my Td5 ^^^^^
Post #980762 1st Feb 2023 7:49am
spudfan
Ireland
A photo would be a big help to anyone else considering doing this. 1982 88" 2.25 diesel
Post #980793 1st Feb 2023 11:47am
Looked under my 110 today and some old build pictures, and it seems I just used a plain normal rubber pipe.
Will have to search and see what I used (plastic td5 tsnk) so maybe it wad just a late 300tdi pipe I used.
Post #980861 1st Feb 2023 9:04pm
MercianRover
I have a pre-TD5 metal filler neck but the part listed in the original post didn't fit (diameter too great on the extension).
I'll measure the filler neck I.D. so we've got some facts to work from.
Post #986192 20th Mar 2023 3:14pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Post #986223 20th Mar 2023 8:03pm
