![]() | Home > Puma (Tdci) > Suitable method to fill hole! |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2460 ![]() ![]() |
Potentially “ QuikSteel Steel Reinforced Epoxy Putty Metal Repair.” Coated on exterior with underseal and sanded and painted on the interior.
Else something like u-pol tiger seal, however gap my be too big for this. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Sika Flex EDT.
Dum Dum putty would be the way I would go with a gap like that I think - https://www.woolies-trim.co.uk/p-1979-body-caulking-10-strips
Waterproof, doesn't dry out and if you are inclined you can paint on top of it. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
I would first try to find what has caused the hole in the first place, especially if it is some form of galvanic corrosion. I am not very keen on those stainless steel finishers! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868 ![]() ![]() ![]() |
I fear that might be a much bigger problem than it first appears
I'm not sure theres meant to be a hole there...
