Home > Td5 > CPS cable snap
alexatnd
CPS cable snap
Hi
Was just replacing my Crank Position Sensor and as i was connecting it up to the wiring harness I noticed that one of the (2) sensor wires was broken. Unfortunately its damn near the plug and as you probably know, its not in the mist accessible of positions.
Don't think i can get a soldering iron in there let alone strip the wires at both ends to maker a connection.
guess what i really need is a new plug with some tails on it
Options ?
Rgds
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #979738 25th Jan 2023 3:26pm
alexatnd
And the solution is go to your friendly land rover parts people who have a plug that fits the CPS with tails on it so all i have to do is cut the old one off and connect the new one ... somehow ....
Simples
Post #979742 25th Jan 2023 3:38pm
rallysteve
Plug is a basic 2pin Econoseal type (https://www.ebay.co.uk/itm/143412803593)
Just cut the old one off and crimp on new terminals onto a fresher section of the existing cable.
Post #979749 25th Jan 2023 4:13pm
alexatnd
ok thanks for the link much appreciated
Post #979754 25th Jan 2023 4:46pm
TexasRover
For these events, I chop the connectors of the 'replaced injector harness', which are of this same type. Have a few in a toolbox in the car. They are pretty good for a quick fix, but the insulation tends to have hardened from sitting inside the engine.
Post #979758 25th Jan 2023 5:28pm
Martin
Site Admin
Definitely a different connector to the injector  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #979763 25th Jan 2023 5:59pm
TexasRover
You are correct different connector. I got confused with the various temperature sensors.
Quickly nipped into the garage where i have a 1999 R380 lying around and took a quick picture for reference. The roundish one is the CPS
Post #979773 25th Jan 2023 6:38pm
Martin
Site Admin
Mr. Green Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #979775 25th Jan 2023 6:42pm
