![]() | Home > Maintenance & Modifications > Leaking bolt in bulkhead window bit |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2422 ![]() ![]() |
Do you mean one of the bolts that goes into the windscreen blocks / brackets ?
If so a new gasket would help https://www.powerfuluk.com/vehicles/land-r...ender.html |
Simonwood Member Since: 16 Oct 2022 Location: West Sussex Posts: 15 ![]() ![]() |
Thanks Ian. Just ordered from your link provided.
Owe you a beer ![]() |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 966 ![]() ![]() ![]() |
We’re you getting a puddle of water in the footwell?
Jim |
Yes that’s correct.
A fair amount. Traced it to the bolt and think the new gaskets above will help. Worse case it’s a window seal? I believe there is a gasket between the frames. |
For the seal... try “Captain Tolley’s Creeping Crack Cure”, I know it sounds like a solution to a medical issue, and always makes me smile when I read the name, but it does find and stop annoying leaks.
https://captaintolley.com/product-info/ Downside is the surfaces need to be dry....but that’s what hairdryers are for ![]() |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2670 ![]() ![]() ![]() |
Its available on Amazon so next day delivery if a Prime member if that helps
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2272 ![]() ![]() ![]() |
Plus one for this - and I too smile when I read the product name (but not when I apply it…) ![]() Also worth sealing the backing plate on the inside as you are removing the bolts for the window blocks anyway. I used clear RTV sealant on the face against the body (obviously!) ![]() |
My footwell puddle was attributed to a hairline crack where the gutter meets the roof above the drivers door. It tracked along the top of the door and down the hinges side. Cured by good old Captain Tolley ![]() |
