![]() | Home > Technical > Programme a new key Fob |
Coolcamper55 Member Since: 22 Apr 2010 Location: Inverclyde Posts: 45 ![]() ![]() ![]() |
I mamaged to lose my set of keys in the mud last week and now only have the one set
![]() I managed to get new keys cut from the local high street and have got a hold of a key fob Lucas 17TN type. The fob needs to be programmed but how? I have looked round the web and just got myself more confused. Is there someone on this forum who has done this and has a surefired method. Very grateful for any help, if there are concerns re security please PM me. Thanks Tommy Tommy 110 XS TDCi |
PM sent
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Anyone who has just bought one of the Nanocom Evolution units should be able to do this for you
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
And worryingly there are a few us...once again sorry for starting the thread
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Can anyone point me towards the link for programming an integrated key, using a Nanocom? Just can't seem to find it.
Thanks , Merlin |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
IIRC,
Go into the 10AS module with the ignition off. Find plip learn and have all your plips at hand. Start plip learn and press the lock button on the plip until the horn sounds and/or the hazards flash, this plip has been learned. Also this has to be done with no RF interference, so you may have to move the vehicle to get the plip and 10AS to communicate. Do the next plip straight after the previous one has been learned, up to a maximum of 4. You have to relearn all the plips when you do this otherwise only the new one will work as that is the only one learned. Once all the plips have been learned click on finish/write settings. Try all the plips. ![]() Brian. |
I know I'll probably regret this as being too easy a question, but what does "PLIP" stand for?
Merlin |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
Put Lightly In Pocket |
Isn't it the generic sound that a lot of car alarms make when armed? Press the button and 'plip'.
Not on Defenders (or any Land Rovers) though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Did you get the new plip working?
Yes and No!
After many attempts I've ended up with the old ones working (again) and the new one can lock and unlock the car. However, when I tried to use it to start the car it didn't work. I wonder whether it is something to do with the corrupted file as mentioned on the Nanocom website. But, when I connect the Nanocom to my PC (no external power supply connected at that time) I can't get the Nanocom to be recognised by the PC. I have tried it with a second computer, but it is exactly the same. Any suggestions? Merlin |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 ![]() ![]() |
Not all 17TN keyfobs are the same.
YWX101220 which is the correct part number for a defender has a built in immobilser chip as well as the radio transmitter. YWX101200 is a freelander 2001 on keyfob which hasn't got the immobiliser chip. If you have the latter, it will work the central locking/alarm, but not the passive immobiliser. If programmed for the alarm.central locking & is working, the immobilser chip should work also. Regards Steve |
Did you upgrade the nanocom to the BBS software? Does the nanocom light up with the external power supply connected and powered up? Also did the garage re instate everything in the 10AS once they found the pin fault? Brian. |
Far as I know the AS10 is working fine. The Nanocom is lighting up an d says it's connected. The thing is the PCs don't recognise the device.
Merlin ![]() |
