![]() | Home > Wheels & Tyres (L663) > Discovery 3 wheels on Defender 2022 |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 840 ![]() ![]() |
A bit of a lottery, a few factory optioned vehicles with 22” come with the larger brake rotors fitted,
so you can end up stuck with 20” as a minimum size even on the D200/250 models, . Check if you have the smaller brakes if it is a D200/250/P300 then 18” a possibility with the smaller rotors, but may need to check offset etc,, if a D300 or P400 then 19” is the minimum with the standard calipers and rotors..but once again could have the larger rotors if shipped from the factory originally with 22” wheels.. nothing is simple with a Landie ![]() MY20 110 P400 SE Defender MY10 3.0 RR Sport |
