Home > Technical > Brake Bias Valve connection
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Hi Folks
I have a 90 with rear disc brakes and no ABS, anyone know how i connect this up. also i have seen pictures of the valve running parallel with say the chassis and others with it 90Deg to chassis which is it Rolling Eyes
Post #977862 13th Jan 2023 2:34pm
geobloke
From the workshop manual... Top image.
As for the placement it is usually found on top of the chassis infront of the drivers side seat box. Parallel or perpendicular it does not matter as long as it is secure and out of the way.
I take it you are converting from drum brakes to disc braked rear axle then?
Post #977887 13th Jan 2023 5:16pm
donmacn
Ah, now. I don't mean to be contrary on purpose, but I think that fella needs to be fitted to the front of the drivers footwell, horizontally.
There's another (earlier?) thing that sits on the chassis leg, driver's side.
I'll see if I can find a pic of mine. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #977888 13th Jan 2023 5:27pm
geobloke
You are not wrong Don, I was thinking of the earlier bias values.
This one does have to be level (horizontal) but it can still be found either on top of the chassis in front of the seat box (footwell) or to the side of the chassis. It depends on the era of Defender and type of Defender (90, 110 or 130). When I was looking for a brake line kit for Miffy I had to go through all the permutations with the seller to make sure I had the right kit.
This is the later biasing valve the earlier one was a weird triangular affair that was located between the chassis rails under a body mount.
Post #977891 13th Jan 2023 5:40pm
geobloke
Ah I knew I had a post - https://www.defender2.net/forum/post931357.html - Page 23, you can see the location of the bias valve on Miffy (2003 TD5 110).
Post #977892 13th Jan 2023 5:43pm
donmacn
Hah!
I couldn't find my pics and post.... because they were on your thread!
Thumbs Up Donald
in the past..
Post #977894 13th Jan 2023 5:54pm
shanecl
Thanks guys for the replies Very Happy I'll get cracking on it now
Geobloke, no I took the defender apart 10 years ago and i cant remember lol
Shane
Post #978304 16th Jan 2023 12:10pm
geobloke
Oh Shane oh Shane... Rolling with laughter Photos mate... Always take photos... Rolling Eyes Rolling with laughter
Good luck with the rebuild Thumbs Up
Post #978307 16th Jan 2023 12:12pm
shanecl
Laughing i know but I've had 3 phones in the meantime and never got the photos off it Big Cry really wanted to do a build trend by ah well Rolling Eyes
Post #978355 16th Jan 2023 4:42pm
