Home > Puma (Tdci) > MOT fail today 'Nearside handbrake' not working
Swac3
Ho hum,
Got the call from the MT station it failed as the left side handbrake wasn't working.
Popped back in and it took me drawing a rough sketch of the defender system for the penny to drop, Lead mechanic wasn't understanding me verbally trying to explain how that was physically impossible and that it was something else.
So looks like i'm pulling a half shaft tomorrow and see what the damage is.
Sigh.. 3 Landrovers
Post #977492 10th Jan 2023 10:09pm
nitram17
How Its something i never thought off before!!How should mot inspectors be testing the brakes without using the rolling road and whapping on the handbrake? Any mot folk on here to tell us how they are supposed to do it?
Post #977504 10th Jan 2023 11:04pm
Sjmmarsh
United Kingdom 2009 Defender 90 Puma 2.2 XS CSW Santorini Black
I’m not a tester, but they should do a road test and use a Tapley meter.
Steve
Post #977525 11th Jan 2023 12:45am
Swac3
Aye, lots of people say you shouldn't do a defender on the rollers but if these guys hadn't done the roller test then they wouldn't have really noticed the near side didn't register any braking. 3 Landrovers
Post #977530 11th Jan 2023 2:31am
A vehicle with selectable 4WD (eg series LR) can be roller tested, a full-time 4WD needs a two-axle roller test rig or road test with a decellerometer. If roller testing, the handbrake can be tested; if road testing the effectiveness of the handbrake should be assessed with the vehicle stationary.
Post #977535 11th Jan 2023 8:43am
landy andy
What damage are you expecting?
I can’t understand the problem apart from a tester who doesn’t understand
Post #977537 11th Jan 2023 8:51am
Surely all they've registered is that you have an open rear diff (like virtually every Land Rover)? That's not a fault - it's just a consequence of the design and there's no need pull anything Confused Darren
Post #977540 11th Jan 2023 9:38am
landy andy
My thoughts exactly.
It is just showing how a diff works.
Post #977546 11th Jan 2023 10:44am
Re: MOT fail today 'Nearside handbrake' not working
Swac3 wrote:
Ho hum,
Sigh..
The only damage is to your wallet and their reputation.
The penny cannot have dropped since they haven't rescinded their stupidity (and it can't fail on the basis that something it doesn't have isn't working, and it doesn't have a "nearside handbrake").
What do you/they actually think is happening, and why do you think anything is damaged (and what good is pulling halfshaft)?
I suggest that you don't waste your time, take it somewhere competent for the MoT and when it passes ask for a refund from the incompetent tester.
Alternatively you could tell him that your vehicle is special since it has a handbrake that works on all four wheels, and the lack of a nearside handbrake is because that on is on the front. Watch him mentally process that!
Post #977548 11th Jan 2023 10:53am
TexasRover
In their defense if you jack up the right rear wheel, the handbrake on the left rear wheel will fail. Maybe they were testing per wheel and did not notice the other wheel spinning. I agree pulling the half shaft does not make too much sense at this point
Post #977554 11th Jan 2023 11:31am
geobloke
Swac3 wrote:
Ho hum,
Sigh..
Thinking someone needs a lesson on the difference between a hand brake and a transmission brake... Rolling Eyes
Post #977559 11th Jan 2023 11:52am
Swac3
OK so now i'm confused as to whats going on with this MOT
So,
Both rears jacked clear of ground
Handbrake ON
Spin either wheel and the other contra rotates, prop static.
Handbrake OFF
Spin either wheel and the other contra rotates, prop rotates.
Handbrake ON, you can not rotate the wheels simultaneously in the same direction
Handbrake OFF, you can rotate the wheels simultaneously in the same direction.
With a single wheel jacked clear
Handbrake ON wheel and prop dont rotate
Handbrake OFF wheel and prop rotate.
Do I have something wrong in my head here or is that working perfectly normally ?
If so, then whats up with the MOT test they failed,
Agh, hopefully someone can set my addled brain straight
Cheers gang
Gary 3 Landrovers
Post #977568 11th Jan 2023 1:35pm
All of that is perfectly normal. What's wrong with the MOT test is that they've tested it on rollers and don't understand how a transmission brake or differential works. Darren
Post #977569 11th Jan 2023 1:40pm
geobloke
As above, perfectly normal. The MOT tester doesn't know how a transmission brake works. It is their failure not your Defenders.
Post #977571 11th Jan 2023 1:45pm
Swac3
Well, Thanks all. Much appreciated even if it exposed my lack of knowledge or at least confidence in what I thought i knew. 3 Landrovers
Post #977576 11th Jan 2023 1:58pm
