Home > General & Technical (L663) > Navigation Auto-Zoom
steam_simon
Has anyone got the navigation Auto-zoom working? Mine doesn't, so travelling on a motorway at 70mph I just get about 500m of motorway (if that) and the arrow moving along it at speed.
I've tried changing it to "off" - no change.
This happens in all modes (North Up, 2D and 3D).
Post #977228 9th Jan 2023 3:22pm
whiterdesign
Does auto zoom not only work when you have navigation set. I.e come up to junctions and map zooms in, which mine does. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #977257 9th Jan 2023 7:43pm
steam_simon
The issue is that it is always "zoomed in" and doesn't "zoom out" when travelling fast.
So, for example, I can't see where I am on a journey - e.g between Leicester and Loughborough on the M1. Just that I'm on the M1 - somewhere. It's so "zoomed in" that it shows both carriageways of the motorway. This can't be right.
FWIW it doesn't appear to change the zoom when approaching junctions.
Post #977288 9th Jan 2023 9:53pm
XplusYplusZ
I have the same problem.. I usually set the zoom in for town driving. But that means when I'm coming up to an unfamiliar motorway roundabout, it's not easy to see which lane on the slip road I should be aiming for.
Are you using carplay or the pivipro nav?
I dont really use pivipro, but I find the manual zoom on carplay (google/waze) is pretty clunky - I haven't figured out how to tell it to autozoom.
Waze is worse as the cartoon icons are so large if you zoom out for motorway driving, they often block out the entire junction i'm trying to navigate.
Post #977606 11th Jan 2023 3:34pm
SN
I run Android Auto (Google Maps) on my 10" Pivipro screen and the inbuilt LR satnav (in satellite view mode when it can actually be bothered to download the images) in the space between the dials (on the full size interactive display) - I find the combo works really well no matter what speed I'm doing (sadly no photos at the mo) Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #977667 11th Jan 2023 11:42pm
XplusYplusZ
I hadn't previously dug into the settings deep enough to find the toggle, but I eventually found it hiding in the settings/apps menu. It was configured to auto-zoom as a default setting. And seems to be working ok for google maps. I'll check waze and pivi-pro tonight.
I'm not sure about android though..
Post #977841 13th Jan 2023 8:36am
steam_simon
It's the pivi-pro navigation on the main screen (not the IDD) that I'm interested in/have the problem with.
Strangely, whilst typing this the dealer rang me (on another matter) and on me mentioning the zoom admitted it didn't work. Clearly it's a software issue.
Post #977877 13th Jan 2023 3:33pm
AndrewS
You can look up and take guidance from the road signs Thumbs Up Whistle Rolling with laughter 130's have feeling's as well you know Smile
Post #977944 13th Jan 2023 11:53pm
haymeister
Japan
Should there be auto-zoom when there is no guidance to a destination?
I tried this morning and auto-zoom only works for me when I have guidance to a destination. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #977946 14th Jan 2023 2:45am
steam_simon
Yes, I’ve noticed if you put destination in, then the system shows the route and zoomed right out. On my previous 2014 X-trail the Nav system would dynamically zoom in/out depending on speed.
The current LR system is permanently zoomed in which makes it useless at higher speeds on motorways..
Post #978149 15th Jan 2023 10:33am
Moo
Ukraine
I just use Apple Carplay. Works a treat.
Post #978160 15th Jan 2023 11:22am
XplusYplusZ
I tested the pivi-pro this weekend.
Things I noticed:
1. It did autozoom at certain points - it was a bit clunky. I think it triggered when it approaches an important junction. It didn't seem to be speed related.
2. I was travelling around 20mph in the city and it was zoomed out a little too far. But for a motorway, at 70, it was probably a little too zoomed in. I didn't test it at speed.
3. The IDD seemed to be slightly more zoomed in than the main screen.
4. When a junction approached I was inundated with turn indicators The main map + a pop-up in main map + the IDD main map + pop-up in IDD.
5. Both Google Maps and Waze (CarPlay) autozoomed better and more consistently than Pivipro.
Post #978300 16th Jan 2023 11:00am
