Home > Puma (Tdci) > Door Seals
Polarismd
Door Seals
I have been working on finding the optimum door seals for my (new to me Landy). I tried both original and OEM door seals and found the original far superior.
One thing that wasn't was the bottom seal. Which was originally a piece of high density foam.
I found on Amazon a silicone rubber seal that works perfectly. It's been on a month now and makes such a huge difference in wind noise from doors and also water ingress. Here are a couple of images to show it in use.
I just thought I would share.
Post #976999 7th Jan 2023 3:51pm
Landymatt
Thanks for sharing this - I don’t suppose you have a link to the seal for the door bottoms do you?
Since my Puma was soundproofed, carpeted and new thresholds added I’ve started suffering from wet footwells, so now looking at options to try.
Much appreciated,
Matt
Post #977102 8th Jan 2023 2:48pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
I'd be very interested in this too! Thumbs Up TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #977123 8th Jan 2023 5:57pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
Me too wanna know, fire away Sir! Thumbs Up
Post #977134 8th Jan 2023 6:49pm
Polarismd
Amazon Link to Rubber Seal
Hi
Here is the Amazon link.
https://amzn.eu/d/7RiIglJ
Chris
Post #977190 9th Jan 2023 11:15am
TexasRover
Thanks very much! Looks like quality item (compared to the consumer stuff at B&Q). Size 14x12 correct?
Post #977192 9th Jan 2023 11:33am
Polarismd
Seal
Hi,
Yes, 14 * 12.
I also used degreaser from Toolstation (WD40 family) and ISO Propenal to clean the sill before I stuck it down. Clean and clean again and then it sticks perfectly.
It's going to come off eventually, but 6m should be enough to do all the doors twice.
I also just ordered the smaller version for the rear door, and will report back when its been tested.
Chris
Post #977194 9th Jan 2023 11:38am
Landymatt
Top info Chris, thank you
Post #977248 9th Jan 2023 7:56pm
