Home > Td5 > Broken ignition barrel
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Hi all,
My ignition barrel is starting to fail. It didn’t spring Back very well to the on position after starting the engine. It also sometimes does not make contact and the car won’t start. I’ve taken the dash apart to have a look and the back of the barrel is loose. When I hold it in with my hand the ignition will work, albeit with poor spring back action.
Can this be repaired or should I just pull the plug on a new barrel? I’d rather repair as I really don’t want to change all the locks!!
Thanks in advance 2002 110 td5
Post #976401 2nd Jan 2023 5:57pm
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
get a new ign lock and barrell they not expensive!
Post #976435 2nd Jan 2023 9:05pm
geobloke
It is also a good time to replace your two door locks at the same time as they probably do not work as well as they should do Thumbs Up
Post #976510 3rd Jan 2023 11:03am
Jimb1978
So not worth trying to repair. I’ve managed to find a genuine one on eBay for £85 as opposed to circa £130 (bought in error by the seller), so you’re right…not worth trying to repair.
I just wondered if it might have been something simple like a self tapper having dropped out that I wouldn’t be able to see until I removed the barrel. But if they are not with faffing with or unable to be repaired then decision made.
Thanks chaps 2002 110 td5
Post #976600 3rd Jan 2023 9:10pm
