Home > Puma (Tdci) > Heated Windscreen Switch = No Light
Page 2 of 2 <12
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
GLR10
Try testing or swapping this out they are not expensive
Post #976500 3rd Jan 2023 10:39am
KISSMYAURA
Assume you have checked both the fuses lol Laughing
should be fuse15 5amp. (passenger fuse box) and fuse96 30amp, other fuse box
Post #976501 3rd Jan 2023 10:42am
KISSMYAURA
you should get power to relay, to make it click then on to the timer, so check fuses first!
Post #976502 3rd Jan 2023 10:46am
nocker65
 2011 Defender 90 Puma 2.4 HT Baltic Blue
nick.bw wrote:
No. Nothing when the button is pressed. Switched the relays around as well to test and nothing
Can I jump on the thread as I am having the same problem?
All fuses are ok
The relay clicks when pressing the switch, but no light comes on.
The screen does not work at all
Post #1026972 5th Mar 2024 9:48pm
Page 2 of 2 <12
