![]() | Home > General & Technical (L663) > Dimensions |
Tommo71 Member Since: 31 Dec 2022 Location: Fife Posts: 12 ![]() ![]() |
When I drop my P525 down to access height my screen shows the vehicle height as 1.92m. Does anyone know if this includes the rear pointing fin camera on the roof?
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 315 ![]() ![]() |
https://www.ownerinfo.landrover.com/docume...c/G3186212
The Dimensions diagram shows the fin included. Normal height is 1971 for the 90 on air, 1970 for the 110. Access height is 40mm less. |
Cheers Nick, so the minimum height for my 110 is 1930mm?
![]() Click image to enlarge Sweating on attached pic..... |
Thanks Nick. Looks like there's an inconsistency between the monitor dimensions and the actual dimensions. So the normal drive height of my 110 shows 1.97 on my screen. If I was fully fuelled with maximum passengers will the air suspension compensate to retain the 1.97m? I'll physically measure mine tomorrow. Too much tatties and veg to peel today!
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3782 ![]() ![]() ![]() |
While we’re on dimensions, does anyone know the width of the doors on a 90?
Yes I believe the air suspension will maintain level heights regardless of load within reason.
My screen shows 1.97 at normal height, 1.92 at access height so there is 10mm inconsistency there. I don’t know if those heights shown on screen are actual measurements or are preprogrammed. Also that diagram doesn’t show the fin but that might just be for display purposes. Of course in real use you would want a decent clearance in multi-storey car parks etc to allow for changes in gradients, pipe work or errors perhaps so in your example it may not be possible but you’d have to try very carefully with someone watching! |
What width do you mean? The length of the door panel, the width out from the car with the door open? |
The length from the hinge to the opposing edge of the door. My driveway is tight so I’m trying to work out how much space I will need to get the door open.
Ah ok, that’s 1330mm edge to edge with the door closed. Mine’s tucked up in the garage at the moment so can’t get the door open fully but that sounds near enough for what you want?
That’s great Nick, thanks.
