![]() | Home > Modifications & Maintenance (L663) > Headlamp Power Wash |
| graemesmith1960 Member Since: 03 Sep 2021 Location: West of Scotland Posts: 80
Had my MY22 D300 HSE 110 for almost 10 months and I just noticed it does not have Headlamp Power Wash! I never even thought to spec it as I had naively assumed that a reasonably hi spec vehicle would have that as standard.
Has anyone tried to retrofit it? The parts are around £100 + VAT (excluding new headlight surrounds which are about £120 each). I'm assuming all the wiring will be there but will it need the CCF updating? Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
Thanks, yes, it is an additional pump but it's only £30 or so. The main issue is if the CCF needs modifying. More research needed! Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey
| Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 474
Ok Graeme, I'am interested
How about the wireloom/harnass ? Hoses / splitter ? When I was rebuilding after respray, 2 hoses and 2 connectors are attached to the Washer fluid reservoir. GAP IIDtool ? Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Thanks for that.
I have had to send my IID Tool back to Canada as it is too old for the Beta program. Once I get a new one I'll have a good look and see if there is anything in there. Defender D350 X-Dynamic HSE 110 MY25 Carpathian Grey |
| rtm89 Member Since: 14 May 2013 Location: North Yorkshire Posts: 261
Very interested to hear if you get orted with retro fitting this. Running one without is a complete nuisance.
| Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448
There is a setting in the CCF to turn it on
MultiCAN-728 Headlamp Wash Fitted This is from the ccf on my car which has them fitted -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Hose front between the washer Jets LR 132136
Jet . LR 132137 Jet. LR 132138 Washerpump for headlights. LR 129849 Still no info over the wireloom... Click image to enlarge Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
| All times are GMT |
