Home > Puma (Tdci) > Puma rear window latches
Vitesse
Hello. I need to replace the small metal window blocks used to latch the rear side glass shut. I have removed all the plastic mechanism but the actual metal block is stuck. is this glued in or just stuck with double sided tape?? Thanks for any help as trying to avoid a shattering experience! Thumbs Up 2015 90 XS Santorini Black
Post #975328 21st Dec 2022 9:06am
Dinnu
There is a rubber gasket between the glass and the external aluminium block. That tends to stick. Need to gently pry it off. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #975330 21st Dec 2022 9:49am
Vitesse
Thumbs Up Thumbs Up 2015 90 XS Santorini Black
Post #975336 21st Dec 2022 10:12am
Ianh
You can use a hair dryer to warm it up a little, it will soften the gasket and ease removal.
Post #975339 21st Dec 2022 10:32am
Vitesse
Post #975340 21st Dec 2022 10:35am
