![]() | Home > Technical > Heated windscreen help |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
Negative to a good ground point on the bulkhead.
Can't tell from the relays view where the positive to the screen should run, but likely to be on the left hand side, probably the bottom hole. But cannot be sure without seeing what relays/timers have been supplied. Can you not contact the company who sold you the wiring kit, as this wiring is specific to them? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| G-P Member Since: 27 Oct 2019 Location: Cambridge Posts: 16
Thanks for you help, I will have another play today.
Waiting on a wiring diagram from the supplier. Click image to enlarge Click image to enlarge Here are some more photos if that helps. |
Excellent
The orange unit is the timer relay, the black relay is used to convert the negative pulse from the factory switch into a positive pulse for the timer. Click image to enlarge Where do the red and orange/red wires go at the moment? The long yellow is for an ignition feed The long green (not the loop) is for the trigger from the switch 1988 90 Td5 NAS soft top
2015 D90 XS SW |
