![]() | Home > Modifications & Maintenance (L663) > You still want a flat floor in your new 90? |
| BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1108
Wouldn’t it be easier to just buy a commercial and have the window covers and bulkhead taken off? 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
| Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 474
I think it was an ad-hoc construction anyway. They should have folded flat.
Basically they designed the 110, let's make a short version and see where we run into. Same as the Front doorcards, armrest to short. Entry to the rear seats to narrow.etc. But it looks fantastic ! For the flat flooring you need a vertical support behind the front seats, I also made under there storage room Click image to enlarge Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
| Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753
I have seen a couple of posts on the Fb groups where owners of US based 90’s have taken out the rears seats and replaced them with the 3rd row u it from a 110 7 seater to give a flat floor with no bar. I’ve also seen a conversion where the boot floor has be raised to the same height as the folded seat backs and a locker or drawer put in the raised boot floor, that way you don’t need to mess around with removing anything that may or may not be structural or playing around with the electrics for the seat belt pre-tensioners or the mild hybrid wiring.
Brickbox - one reply I had on an Fb group was that by doing this to a car version you will not have to pay the huge Clean Air Zone entry charges that the Commercial version will be subject to, over the life of the car I would image the avoidance of the CAZ/ULEZ fees will catch up with the saved VAT on a business purchased Commercial 90 as there isn’t a requirement to re-register the passenger car to a commercial. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Thank you for clearing that up. I hadn’t thought of the commercial registration issues.
This now makes complete sense. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
| Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 607
I'm not sure if you're implying if it is, but the new Defender Hard Top isn't subject to the London ULEZ charge. https://instagram.com/bentheoandrews |
| Brockmoor Howard Member Since: 12 Dec 2021 Location: antwerp Posts: 28
I have got my 90 5 seat very nicely converted into a commercial 2 seater with load space completely flattened out with identical original design floor. Cost €2000 +vat
| tooslo964 Member Since: 25 Jun 2020 Location: Aberaeron Posts: 42
That sounds impressive, was that just for the parts ?
Would you have a list of what was required ? |
It came back from builder completely finished.
They return loose the rear seat, so if you are a handy guy you can make a light structure to have a nice seat in your cargo space or a good relaxing seat for your man cave ! |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3524
Brickbox - one reply I had on an Fb group was that by doing this to a car version you will not have to pay the huge Clean Air Zone entry charges that the Commercial version will be subject to, over the life of the car I would image the avoidance of the CAZ/ULEZ fees will catch up with the saved VAT on a business purchased Commercial 90 as there isn’t a requirement to re-register the passenger car to a commercial.[/quote]
I'm not sure if you're implying if it is, but the new Defender Hard Top isn't subject to the London ULEZ charge.[/quote] lndeed, sounds like another FB error, the Commercial version is exempt from all U.K. CAZ's As to the future, who knows, but l don't think it will change until 2030 at the earliest. Most new CV's are still diesel due to the range issues with EV's VW have an all electric van just come out but when loaded up or towing the range drops to just over 100 miles, no good for a van unless it's all local work. |
| kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074
The only down side of the commercial is lower speed limits.
