Home > Puma (Tdci) > 2.2 or 2.4 ? and other questions
Page 1 of 4 1234>
jerseyman
Followiing on from another thread I posted about comfort levels on the new TDCi, I am near the point of going for a new 90.
I have just had a call from the (apparently) only L-R salesman from the only dealer here, and he seems to share my concerns about the DPF on the new 2.2 for use in Jersey He reckoned that it may still be possible to get a 2.4 and is going to phone around.
I understand that the 2.2 is more refined than the 2.4 - one of the reasons that I fancy a TDCi in the first place. But are there any other reasons that MY2012 is preferable to MY2011?
As an aside I went to the showroom and they had a 110 XS there - but no salesman to ask questions of - so managed to have an uninterrupted look around it.
There was no plastic wheel arch protection fitted at the front, are these now omitted?
Has the chassis painting changed recently?, this one seemed to have a near gloss black finish not the satin I am used to.
(I have had a search but apologies if this has been covered before)
Brian
Brian
Post #97519 1st Nov 2011 4:41pm
jst
chassis is barely painted or anything else now days, so colour has changed, mostly due to lack of underseal!
i would be tempted to stay clear of anything with a DPF that doesnt get out and about for sustained periods. For jersey (30mph tops?) i wouldnt be buying a vehicle with a DPF.
on the other hand you can remove them! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #97539 1st Nov 2011 6:16pm
TJ101
Re: 2.2 or 2.4 ? and other questions
Brian
Where did you get that impression from ??,, as it not
The other way round 2011MY all the way California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #97565 1st Nov 2011 7:29pm
isv
I faced the small dilemma last month.. Went for the 2.4 110 XS Utility and very happy with it... I got a great deal and easily saved enough to pay for my fuel for the next couple of years... Smile
Post #97574 1st Nov 2011 7:51pm
dgardel
Italy
jerseyman wrote:
I understand that the 2.2 is more refined than the 2.4 - ..............
Where?
in my opinion 2.4 and 2.2 will be the same car.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #97584 1st Nov 2011 8:28pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
dgardel wrote:
Where?
I think this is in reference to the 2.2 being fitted with a noise blanket/cover as standard.
It said this in the original marketing blurb.
Post #97591 1st Nov 2011 9:17pm
spudfan
Ireland
I find the 2.4 Puma quite refined and quite. Any quieter and I'd be able to hear the Mrs. think. Bad enough being able to hear her talk....... Whistle 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #97626 1st Nov 2011 11:10pm
jerseyman
Thanks guys,
If the rumoured additional refinement of the 2.2 is down to an engine blanket then that would seem to be a bit of a non-event as I will fit a Noisekiller kit anyway.
Brian
Post #97659 2nd Nov 2011 11:03am
dgardel
Italy
Ads90 wrote:
dgardel wrote:
Where?
Nothing that you can not add on the 2.4........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #97661 2nd Nov 2011 11:22am
MK
it uses less oil.......6.2l Puma 110" SW
Post #97669 2nd Nov 2011 12:44pm
Sockpuppet
Find someone with a 2.2 transit and ask them if the DPF have shagged itself in Jersey as it's the same engine.
Post #97673 2nd Nov 2011 1:31pm
dgardel
Italy
? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #97696 2nd Nov 2011 3:39pm
jerseyman
That's exactly what I've asked the Dealer to do.
Brian
Post #97724 2nd Nov 2011 6:03pm
jerseyman
Right I have just had the salesman on the phone about the 2.2 DPF issue.
He has told me that the 2.2 is the same engine as in the Freelander 2 and they are not having problems with the DPF on those. Now it is my understanding that it is not - unless the 2.2 engine in the F2 is also a Transit engine?
When I queried it he says "that is what he was told by Landrover"
Can anyone shed any light on this?
Brian
Post #98045 4th Nov 2011 12:35pm
Martin
Site Admin
Wrong - the 2.2 engine is NOT the PSA DW12 from the Freelander 2, it is a Ford Puma TDCi. The same basic engine as before.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #98046 4th Nov 2011 12:37pm
Page 1 of 4 1234>
