![]() | Home > Faults & Fixes (L663) > Windscreen - - - |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472 ![]() ![]() |
Wasn't this an issue on early cars?
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Your ADAS ( Advanced Driver Assistance System) will need re calibrating with a new screen, a reputable glass company should include calibration in the replacement process https://transparencyautoglass.com/blog/wha...libration/ Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
The windscreen company will either be able to recalibrate it, or of not then a dealer can do it. These systems are very common now so places are used to doing them.
I had my screen replaced by Autoglass at 4,000 miles and they did it no bother, including calibration. I had them use a genuine screen as the car was only a few months old at the time. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3496 ![]() ![]() |
l ordered the solar reflective windscreen as this is supposed to be less prone to the cracking issue, but this option now seems to have disappeared from the online configurator.
gilesn Member Since: 12 Jun 2013 Location: Glos Posts: 61 ![]() ![]() |
Update -
Sort of booked in now - I say sort of as I have to wait till the windscreen is availble. Hopefully that will be in the next couple of weeks. Will have to be fitted at a 'fitting' center - as yes the camera system will need to be re-calibrated. Did a little more research in to this - yes a millimetre of error at the winscreen will equal a far bigger error 100 to 200 meters up the road. Hope the windscreen stays on the current leadtime as with the colder weather now everytime i put the heater the cracks in the screen grow - they are now over 12 inches long!! |
Done - fitted -
Turned up at the fitting garage. Replacement screen was ready on a stand. Was told it would take approx 2 hours - depending on the glue/resin to cure & the 'calibration' Went back in under 2 hours - all done fitted, cured & calibrated. Have driven it home - lane depatured worked (as normal/before), spped limit signs were recognoised as before. Will check the headlight assist tomorrow morning. Only thing I was 'dissapointed' with was its not a genuine LR windscreen. I asked why not - as my appointment was delayed to get the like for like replacement but the fuitting guys said they get that alot. People are told they will get an OEM replacement - then when they turn up its a non OEM windscreen. With the 2 big (over 14 inch long) cracks I had - i needed to hget it repalced. Was amazed how thin the screen is - didn't measure it but i don't think it was over 2mm |
One positive.
Maybe the OEM windscreen will be less prone to cracking in the future. l've read of a few where the screen has cracked. l remember this happened years ago when the Ford Sierra first came out...if you parked with one front wheel on a curb the screen could fracture! l doubt this is the reason for the Defender screens failing, maybe it's because the glass is so thin. |
