Home > Puma (Tdci) > AUTOTERM Flow 5D
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
AUTOTERM Flow 5D
AUTOTERM Flow 5D as an alternative to the Thermotop C?
Does anyone have any experience?
It seems there is a kit available from Naka
Post #974116 9th Dec 2022 11:09pm
Mago
Germany
Hi,
the Autoterm heaters are a pretty good alternative to the Webasto heaters. Right now I´m thinking about an Autoterm 5D for my Puma, I've heard some good feedback so far.
Take a look at tigerexped.de ( https://www.tigerexped.de/autoterm-flow-5d...ng-12v-acc ) too, they are the importers in Europe and have an amazing technical support.
Naka sels a bracket, made for TDCi 2.2 or 2.4, the Montagehalter Webasto Thermotop EVO5 which will fit the Autoterm 5D as well:
https://www.nakatanenga.de/elektro/geraete...evo5?c=115
Important note: the mounting bracket only fits if the air intake in the engine compartment has been adjusted (e.g. with the optimized air intake or the SN4 snorkel systems)
Maybe there is another solution?
Greetings,
Very Happy Defender 90 TD5
Defender 110 Puma 2.4
Post #974572 13th Dec 2022 5:18pm
Yannis
I have been considering the same.
I have found them here, another EU dealer;
https://www.autoterm.cz/it/prodotti/flow-5dbinar-5s12-diesel.html
I have seen the bracket but I am RHD so it would be going the other side from the air intake. The 5D is a bit smaller that the TTC. 220/90/136 vs 235/106/163 respectively. That might give more options for mounting.
Plenty of places on the chassis rails but I’m not sure if these units will like being submerged if crossing a river or ford….?
Post #974576 13th Dec 2022 6:46pm
Mago
Germany
Take care about the pump, at autoterm.cz they use a Bosch pump, at tigerexped they use the Thomas-pump.The Thomas pump is very quiet and has an integrated end stop.
Driving a RHD model is good for the airintake problem. Due to the smaller dimensions there will probably be more space...
I´ve seen a Defender in Norway with an 5D mounted to the frame, more or less under the engine. It is by far not the optimal position for me, because of water (crossings) and the gigantic amount of salt they put on german roads while its cold.
Matzker puts the heater on the same place like naka, but without having problems from the airintake:
https://www.matzker.de/defender-standheizung.html
Here you can see the two options, recomended by Webasto:
https://www.offroad-forum.de/pserv.php?img...8335zy.jpg
https://www.offroad-forum.de/pserv.php?img...8334oa.jpg
Here we have the mounted to the frame option, which I think is not the best solution:
https://matsch-und-piste.de/wp-content/upl...erbaut.jpg
And then there is the option to mount it into the right front fender, behind the headlight. Right now this would be my preferd place.
Finally I found some pictures (maybe you have to log in... Rolling Eyes )
https://www.blacklandy.eu/blboard/vb5/node...post579964
https://www.blacklandy.eu/blboard/vb5/node...post580723
Greetings,
Post #974600 13th Dec 2022 9:30pm
Yannis
Good point regarding the pump.
I tried to sign up to see the pictures but I can’t seem to find the answer to the “are you a real human” question… Laughing
I have 3 locations in mind;
1 in next to the heater blower. Maybe there is room on the RHD as I have seen a webasto mounted there but the air intake for the standard heater had to be modified for it to fit which I am not keen on doing.
2 in the rear wheel arch. I have the Gwyn Lewis mud guards so there is an area that stays out of the road spray etc specially with a extra bit of sealant
3 behind the headlight on the left but there are some things behind there that would need relocating first.
2/3 the run of the hoses is longer than ideal, but it will only be loss of efficiency from the heater as long as there is a bypass valve installed for the engine coolant so it doesn’t have to take the extra long run.
https://mvheating.co.uk/product/bypass-valve/
Post #974611 13th Dec 2022 11:11pm
Mago
Germany
So in case you´re a real human Whistle , here is one of the pictures:
I´ll have a look under the bonet the next days, right now it´s too cold...
The rear wheel arch is an interessting idea, never thought about it.
A nice sideeffect are the warm exhaust gases coming from the 5D which could be used to warm up the Diesel filter.
Greetings
Post #974689 14th Dec 2022 9:24pm
hornet
As a hint: you also have to think about removal and installation in case of a malfunction/troubleshooting.
I have my Thermo Top C in the usual place in the engine compartment and i am happy about it. There are certainly more elegant but less accessible places. The price difference to webasto is not significant, but the service network of autotherm is much thinner. Where do you see the advantage(s)?
Post #975434 22nd Dec 2022 9:00am
Mago
Germany
Hi Hornet,
the point of troubleshooting is very good! These days I had a look under the bonnet, you´re absolutely right.The place behind the right headlight might be nice, but the "usual" place is simply the more excisable one.
I do have an Autoterm 2D and I´m very happy with it. So I thought, a second one is a good idea.
The thinner service network is a point to think about, but so far I had no problems with it.
Greetings,
Post #975983 29th Dec 2022 5:00pm
hornet
I have one more information regarding the fuel pump arrangement. For over 10 years now I have the pump for my Websato TTC in the direct fuel supply line fitted with a T-piece after the filter, *without* direct extraction from the tank. I don't know if this would also work for 2.2l models, but it has been the perfect solution that works flawless since then and without having to intervene in the tank.
Post #976755 5th Jan 2023 1:14pm
