![]() | Home > Puma (Tdci) > Dashboard Warning Lights |
Thug Member Since: 02 Aug 2022 Location: Johannesburg Posts: 20 ![]() ![]() ![]() |
Went down and started the vehicle 10 minutes ago, dashboard lights have disappeared.
Obviously a wet connection, somewhere. |
Had a reoccurrence of the warning lights yesterday afternoon, so took the vehicle into the garage.
No warning lights this morning but the garage plugged in the diagnostic reader and reset the fault. Said it could be the ABS pump on its way out. 5 minutes after leaving the garage, going round a bumpy corner, warning lights re-appeared. I'm not really happy on taking a punt that it might be the ABS pump seeing that it's bloody expensive but at this point I think a second opinion is probably necessary. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6670 ![]() ![]() ![]() |
Could be a loose/failing wheel speed sensor?
What fault was the ABS module reporting? ![]() ![]() |
Unfortunately, I didn't bother to ask, will see if I can find out tomorrow.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4281 ![]() ![]() ![]() |
I've had this problem twice now, the first time it was the shuttle valve failure on the ABS pump, the second time it was a wheel speed sensor that had come out of the housing a bit. ON both occasion reading the ABS fault codes narrowed the problem down easily. 2007 110 TDCi Station Wagon XS
Thanks for that info.
I have an obdlink lx reader that I’ll see if I can get code off tomorrow. |
You won't get a code with a generic OBD2 reader, the Wabco isn't OBD2 compliant.
Thanks.
Guess I’ll be visiting the garage again. |
GuJa Member Since: 03 Oct 2017 Location: Elsfleth Posts: 21 ![]() ![]() ![]() |
Well, I had nearly the same. It was a faulty sensor. I bought the cheapest I could get (25 €) and my garage got another 25 € for changing the front sensor. Problem solved (more than 50.000 km now). By the way the LR garage wanted more than 500 €!!!
I’m away at the moment, so haven’t had a chance to follow up.
I have though decided to order myself a Nanocom and the 15% Christmas discount will pay for the courier. Once I receive it in the New Year, I’ll report back on the error codes. |
