![]() | Home > Maintenance & Modifications > Torque Wrench - recommended or reviews |
callumgodfrey Member Since: 21 Feb 2016 Location: warwickshire Posts: 5 ![]() ![]() ![]() |
I use a Halfords 1/2 inch and it's very good (I use it every day at work) and passes calibration every 6 months.
Link: https://www.halfords.com/tools/hand-tools/...=undefined |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
Ditto
I have a Halfords one, came in a good box and when checked on work Torque meter is spot on for its intended range, DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 884 ![]() ![]() ![]() |
A lot of industry use Norbar
https://www.norbar.com/ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
Depends on range, budget, and a few other factors, but classic Britool is hard if not impossible to beat.
The Halfords pro ones are hard to beat, I’ve had mine for 12 years, i have the 0-60 3/8th and 60-200 1/2
Another vote for the Halfords one. I've had mine for about 4-5 years and it's great for the price. Darren
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
I’m pretty sure norbar make Halfords advanced range.
I have two norbar pro wrenches, covering a full range of torque settings from 10 -340nm. They are also dual scale , Newton meters and foot pounds. A helpful list on using and storing a torque wrench. The ten things you should know about your torque wrench - https://www.norbar.com/News-Events/Blog/Ar...que-wrench |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Halford do source their torque wrenches from Norbar(i think) i cannot fault them...Teng are also good but at the cheap end Draper would be sufficient for the DIY er..I have never ever had a problem with a Draper product.... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20980 ![]() ![]() |
Draper for me, perfect for occasional home use never had a problem. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Not sure if it is still the case but the Halfords pro ones used to be made by Norbar i believe.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
I can remember being warned off Norbar when I started serious spannering because they were not very good at all, but that was around 1970 and since then there has been a major transformation for the better.
I didn't realise until just now that Norbar is now a subsidiary of Snap On tools. |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 871 ![]() ![]() ![]() |
What is this 'torque wrench' that you speak of?
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Maybe is irrespective of brand (or perhaps the good ones have better internals), it is a good idea to release the pressure from the spring (set torque setting to 0) when it needs to be stored away. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
I've had two TENG ones for about 20 years! Both work well. One for smaller stuff (up to 20nm IIRC) and one for bigger stuff (approx 19 - 130 nm). Been very reliable. Would recommend.
Looks like these: https://www.tengtools.com/products/torque-...h-20-110nm Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
