Home > Td5 > Injector Fault |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 126 |
First things to check would be fuel pump relays and change the fuel filter rebleed and try to start. Could also be the fuel pump in the tank this may need changing or could be struggling to lift fuel and may need cleaning The fuel pressure regulator normally drops fuel down the back of the block and onto the gearbox on the inlet side hope that helps
10th Nov 2022 12:24am |
Mat4x416 Member Since: 09 Nov 2022 Location: Centre Posts: 3 |
Thank you for jour answer
I will check it all I took advantage of the cleaning of the diesel circuit to replace the filter |
10th Nov 2022 8:37am |
Hi,
The problem is solved, I had a wire in my engine harness which was damaged due to the friction of the harness on the alternator Thank'u |
6th Dec 2022 9:55pm |
