Home > Td5 > Fuel Pump or Relay?
Page 2 of 2 <12
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
geobloke wrote:
At the very least it is worth opening up the cover just to see where the singeing originated. I had to replace all the yellow relays in Miffy. The contacts within the relays had badly eroded over time. Caused the overheating and blackening, plus some irritating running issues.
I did pull it apart, but there wasn’t anything too obvious. Perhaps a little bit of discolouration from heat.
I’ve replaced the battery as well, as it had completely died. It wasn’t holding its charge for long at all. Possibly a contributing factor.
Camelman, no oil in the plugs. However, I have changed the harness in the last couple of years as a service item. A very easy job indeed! I know there’s now an aftermarket harness on the market that is supposedly a fit and forget item. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #972969 30th Nov 2022 5:43pm
Procta
I am starting to suspect my in tank pump is failing, After todays test. Would yours not pick up after 40 mph? mine will not go over 40 mph, its starts to struggle, and wants me to change down, and starts to idle a little rough. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #974468 12th Dec 2022 9:09pm
BaronDefenders
Mine was fine to 2,500rpm and then spluttered. Now that the relay has been replaced, the pump makes a strong noise and performance is fine. Charlie
2002 Td5 90 (SOLD)
Post #974473 12th Dec 2022 9:59pm
Procta
where is the fuel relay located? something i can check tomorrow. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #974474 12th Dec 2022 10:06pm
htb2
Wales
Under the drivers seat, nearest the transmission at the rear are two yellow relays, one of them is the fuel pump relay. On mine its the rearmost one,
Post #974475 12th Dec 2022 10:17pm
Procta
Post #974477 12th Dec 2022 10:37pm
BaronDefenders
If you count 1 to 3, 1 being towards the rear - that’s the fuel pump relay. Charlie
2002 Td5 90 (SOLD)
Post #974480 12th Dec 2022 11:13pm
Procta
Thumbs Up i will also check the crank sensor connector and sensor tomorrow too, in case that's causing trouble too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #974485 13th Dec 2022 1:00am
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
You need to be careful because with old trucks it is quite possible that the relays have been moved about and are not in the correct position.
Had that problem on my truck and I read similar on here too.... TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #974501 13th Dec 2022 9:23am
Martin
Site Admin
Best to ID the Td5 fuel pump relay from the wire colours:
White/Purple
Purple/White
Brown/Orange
Blue/Purple
In descending wire size order.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #974543 13th Dec 2022 1:02pm
TexasRover
Fuel pump relay must the weakest point in any car. I have had Volvo's, Mercedes, BMW, Porche, etc all suffer from burned out relays, typically at a parking lot. They obviously carry a lot of load, but you would think they could make them solid state! At least the Td5 it is just an ordinary relay so cheap to replace even preventative, say every few years.
However looking at your socket, you might want to gently remove the terminals one by one (battery disconnected of course) and clean them up and tighten them up a little. Then the new relay will seat properly and you don't start building up heat and burning up the new relay with a poor connection.
You should also watch a few of these Vice Grip Garage Video's, its amazing what can be fixed on the side of the road. It ain't dead till you tried everything. I have dismantled carburetors on the side of the road. The only time I called in the tow truck what when the clutch (hard pipe) failed on my S3, I could have driven it home without a clutch, but it was not worth damaging the gearbox (and the recovery was free..)
Post #974553 13th Dec 2022 2:22pm
Page 2 of 2 <12
