![]() | Home > Puma (Tdci) > Puma Defender Mid Crossmember Replacement |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2530 ![]() ![]() |
https://www.defender2.net/forum/topic70049...rossmember
If you do a search there are a few topics on it, like the one above. |
MSmith7069 Member Since: 26 Apr 2021 Location: South Yorkshire Posts: 12 ![]() ![]() ![]() |
Thanks,
I have had a look around and I am struggling to find anything that is specific to the puma models. Will continue to look. If anyone has any other tips, please let me know |
Your dead right, I have done a good search and can’t find anything either, perhaps Puma mid crossmembers have not had many issues yet due to lower age.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891 ![]() ![]() ![]() |
I think that the Puma mid crossmember is very similar to the TD5... The job itself will be pretty much the same I'd imagine
Thanks for your reply.
From what I can see online when looking at the part the puma mid member has four uprights which are welded to the part. it is these that are stopping it from being slid into place. Not sure if they make a bolt in one but I haven't come across one unfortunately. |
Take a look at YRM... I think you'll find what you need there..... Galvanised too!
Edit:... I can't find a crossmember with bolt on uprights either 😕 You'll have to wait for a Puma owner to show up and advise |
