![]() | Home > Td5 > Central locking help!! |
Jackfirman98 Member Since: 28 Nov 2022 Location: Aberystwyth Posts: 6 ![]() ![]() |
I believe the immobiliser and 10AS is the controls system, maybe look for from wiring from that, and also inside the door panels towards the rear of the door if memory serves well
2hel Member Since: 28 Nov 2022 Location: Essex Posts: 182 ![]() ![]() ![]() |
Well, I'm sort of assuming (hoping) its electrical and an easy fix
Not so sure about easy ahaha, I have mine to sort out yet π If your immobiliser is disabled that I believe disables them too
well im totally new to defender life so if anyone can help me with things to check and where to find them it would be appreciated
10AS (alarm system control) should be behind the dashboard, Google if it you'd like to know how it looks π Looks kind of like a rectangular can
By behind dash, I mean speedo console π€
Thank you ill check that first!
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
Isnβt it controlled via nanocom π€
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 971 ![]() ![]() ![]() |
Plug in a Nanocom and select 10AS immob. See if it is disabled.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
In theory shouldn't the dashboard blink? And also the key for work?
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5948 ![]() ![]() |
An easy place to disconnect the CL would be the actuator in the drivers door. That way other parts of the security system still work.
