Home > Maintenance & Modifications > Thermostat and rad bleed plug 300tdi
TomB8
United Kingdom 1994 Defender 110 300 Tdi HT Arles Blue
Hello,
I need to replace my thermostat because my engine isn't getting up to temp. Stupidly, I didn't read a how to first which said I needed new bleed plugs and don't really want to pay shipping for two of the plastic ones. I know there is the x-eng plugs but they seem a bit steep at £9 and I would rather like to do this today. I have read of people using 1/2 rad plugs but it isn't clear how they seal in the hole.
Will this (https://www.screwfix.com/p/flomasta-male-flanged-plug-x/98635) be alright and do I just put ptfe or an o-ring on? Or do I give in and but the x-eng ones?
Sorry if this has been covered before, but I have done hours of reading and no one seems to detail how to seal a rad plug.
Thanks,
Tom
Post #972447 26th Nov 2022 2:30pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I am no expert and no mechanic so please bear that in mind when you read this response.
I use ptfe tape on many things that have a thread. I do it for two reasons - firstly to seal the thread and second to stop threads binding.
You need to be careful when you take them out as the tape can come off and drop I to what you are taking them out of.
I have seen one thread where they used a rad plug that had the bleed screw. I have never done this but when I saw it I thought what a good idea!
Post #972484 26th Nov 2022 7:00pm
donmacn
Once upon a time I used a brass radiator plu here (thermostat housing). Worked fine - and it would get you out of a jam temporarily - but when the time came for me to remove it, it had 'bonded' itself solidly to the thermostat housing and was a real pain to remove.
That said, even the plastic ones can be a pain to remove if they've been left in too long. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #972486 26th Nov 2022 7:03pm
Mossberg
Getting the plastic one out of mine was very difficult. I had to butcher it to remove it and I wouldn't fit another. I can't remember if the brass one had a rubber O ring or not?
If the brass ones also bind, the next time I remove it I will refit using ptfe tape.
Post #972494 26th Nov 2022 7:34pm
Litch
Been using the X-Eng ones for getting on for 14-years now and find them ideal.
No 0-rings, I have always just used PTFE tape and never had an issue.
 ONE LIFE, GET IT!
Post #972567 27th Nov 2022 12:26pm
