![]() | Home > Technical > Rear tub adjustment |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3648 ![]() ![]() ![]() |
Mine, a pre 200tdi just sat on the 6 tabs that are welded on the chassis. There are rubber isolators between the tub and the chassis, that are pop riveted to the 3 tub under floor members. Check that yours are not missing.
Was there any welding to the bulkhead outriggers that could put the bulkhead( hence the A post) a bit out of alignment? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Pike3450 Member Since: 04 Feb 2022 Location: Sussex Posts: 16 ![]() ![]() |
Cheers for the response dinnu
Figured it out now. Rubber pads were all there. Had to raise tub at seatbox end 3mm too get door gap right. New chassis. Thought I’d ask before I removed everything, and was missing something Cheers |
